![]() | Home > Technical (L322) > A new fail to start issue. Sometimes |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
I had a similar fault on an old p38 and it turned to be a corroded battery lead from the battery to starter motor the leads corrode inside the insulation I just doubled it up never had an issue again might be with a try |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 ![]() ![]() ![]() |
Thank you Made in Scotland frae 'Girders' |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Well done Boffa |
Update
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
The following diagram is the key one from the workshop manual.
Awsome. Thank you
