![]() | Home > Technical (L322) > Whats that noise ? |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Bushes would be my first guess. Had similar on the left on cornering. Lower arms both sides sorted it out. 2010 Disco XS TDV6, 2009 Freelander 2 GS
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 ![]() ![]() ![]() |
I hope its that, also it feel different when turning left than it does right !!!!!!
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
if your around 70-90k then chances are its your lower balljoints 2004 black Vogue TD6 |
+1 depends on your roads as to how quickly they wear out. ![]() |
Im at 50k but out here in spainwhere its hot and dusty !!!!! |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2068 ![]() ![]() ![]() |
Yep sounds like ball joint ptoblems.
How can i check what the noise is !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Driveing me mad !!!! |
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 ![]() ![]() ![]() |
How can you check? Jack the front of the car up and grab hold of the wheel. Look at the suspension components while you are wiggling the wheel and replace whichever part you see moving. Not sure you should be reading this bit. |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
this is the nearest post I could find to address my recent problem................
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
i know this is an old post but i am having the same problem as described above. Single knock when braking not all the time but its very annoying. Did you manage to find out what this was??
