Home > Technical (L322) > Oil in spark plug well.
alistairh
Changing my plugs and I've descovered oil in the back 2 plug wells.. oils not new as I've just changed it and it appears to be historic..any ideas?
Post #434820 13th Apr 2017 6:37pm
alistairh
Indication of oil high up on the cover..gaskets?
Post #434821 13th Apr 2017 6:43pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Hi Alistair, your profile doesn't say what FFRR you have......
If however it is a 4.4 with the BMW M62 engine this is a classic issue, rocker cover gaskets go hard and leak oil into spark plug hole, eventually degrades the boot on the plug/coil pack and you get a mysterious misfire Very Happy
Not a big job, and whilst you're at it, if you haven't done so already think about cleaning/changing the PCV valve.
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #434829 13th Apr 2017 7:28pm
err, alistairs profile is visible if you click on or hover your mouse over the little car underneath the username.. ... - .- -.
Post #434831 13th Apr 2017 7:35pm
alistairh
Thanks for reply.. cam covers will be the next job on the cards I think. Already evidence of a leak on the underside of engine as well.. did the Pcv system already and I suspect the engine mess is because of this..
Post #434834 13th Apr 2017 8:03pm
alistairh
One thing I've noted since changing the plugs is my dodgy idle that would fluctuate between 800/1000rpm is gone? Reckon I've found the culprit( I hope) 👍
Post #434835 13th Apr 2017 8:09pm
holidaychicken
If you have oil at the front of the engine then your vanos solenoid seals and upper timing cover gaskets are probably also shot.
Make sure you apply the sealer in the right places when you do the cam covers
Post #434855 13th Apr 2017 11:31pm
alistairh
Will do Thumbs Up is the vanos seal a big job interms of access? If not I may do both sets at the same time.
Post #434867 14th Apr 2017 7:35am
holidaychicken
The vanos solenoid seals is easy, just two bolts, you could do the non return valves at the same time with the use of a special deep socket and long M10 fine pitch bolt. You can see where the seals sit in my fots of the left and right bank.
To do the vanos solenoid seals you don't have to remove hardly anything to access them. you can see they are held in place with just two bolts
The upper timing covers are a lot more involved but you can see from my fots they were leaking,
Post #434875 14th Apr 2017 9:23am
alistairh
Brilliant. That's a huge help buddy. Will get all the seals ordered today. Thanks again
Post #434876 14th Apr 2017 10:07am
alistairh
Ordering cam and vanos gaskets today, what Else do I need to order? Screws/bolts for cam covers? Not too sure and I want to have it all at hand . Thanks
Post #434878 14th Apr 2017 10:32am
holidaychicken
I have a list somewhere, you need the two types of rubber washer for the cam cover bolts as a must.
You need the loctite sealer to put on the sealing face at the rear by the half circle cut outs in the head and by the front timing cover.
if you are going to change the vanos solenoid valves you will need them but you will also need the tools.
I'm a bit stuck for time but i have all the part numbers somewhere.
vanos solenoid NRV
LYF000050 BUSH - ROCKER COVER 4.4L V8 G-CAT L322 RANGE ROVER VOGUE 6 off £1.13 £6.78
LYF000030 BUSH ROCKER COVER 4.4L V8 G-CAT 16 off £0.57 £9.12
also have a read here and make sure you have a copy of Rave manual
http://www.beisansystems.com/procedures/m62tu_vanos_procedure.htm
Post #434892 14th Apr 2017 1:31pm
alistairh
Different class mate Thumbs Up did a read up on the vanos solenoid part and going to do that with the gaskets. Thanks a lot.
Post #434904 14th Apr 2017 4:17pm
holidaychicken
Cool, this is the correct sealant to use, good luck Smile
http://www.ebay.co.uk/itm/Loctite-SI5900-H...w-VIh7xz_w
or this
http://www.ebay.co.uk/itm/OE-Quality-43204...SwWxNYq~05
eurocarparts is often cheaper to buy on ebay and then collect in store if you need it quickly
Post #434907 14th Apr 2017 4:39pm
