![]() | Home > In Car Electronics (L322) > Speaker upgrade |
| Lee's Dad Member Since: 05 Jun 2011 Location: In with the POPE Posts: 54
Did you learn all your skills from your dad, Grasshopper |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
grass hopper |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
not sure, just thought if your crossover is pushing mid to low to the door speaker there will be no high range for the tweeters, will it distort the high range, what was the impedance of the ones you removed 4 ohm's, not sure it will make any difference but as you have made a neat job of fitting them, would not want them to cause probs with your amp... V8 facelift Range Rover Autobiography 22" wheels.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
In my last 04 FF i put the speakers from an 08 VSE Harmon Kardon system including the Sub Woofer (used and rewired the wiring from my sub box) and it was a massive improvement...
@ daveo ill double check later
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I must admit to being a little disappointed with the standard stereo in my Vogue. Gone from the Harman Kardon setup in a Disco 2 ES, and have a LINN system at home.
| farmercowley Member Since: 10 Apr 2017 Location: weston super mare Posts: 14
Was your door card easy to remove? I'm tempted to get some 6 inch fly component speakers so I have separate tweeters to replace and pretty much do what you have there, how was your outcome? Would you say it's worked as you wanted it? Cheers |
Do any of you guys no if it's safe to take the power off the live wire in the boot for an aftermarket sub? |
| mikeyyn Member Since: 17 Oct 2011 Location: Notts Posts: 53
Not sure about the speakers but it not too hard to take the door card out, I needed to replace a wing mirror. Videos on You tube show you how. |
