![]() | Home > Technical (L322) > TDV8 no power, white/blue smoke |
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
Is it loosing coolant?
| LASBAM Member Since: 04 Apr 2017 Location: Reutlingen Posts: 26
No the car is not loosing any coolant. I have already taken off the top intercooler hoses. They were both okay but it was a little bit oily. Also the Air filter had a bit of oil splashs on it.
I don't understand oil on the air filter.
Hello together,
| hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294
That's a big job, good luck with it...... |
I know this Video very well. But it is really necessary to drop the engine and gearbox? I found this russian video which shows there is a possibility leaving it inside.. Any ideas which way is the better one |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
My indie says there is no way to confidently change the turbos without removing the engine. Maybe there is a way but I would Imagine it would be even more hardship. 2015 4.4 AB
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
I have rave for it and the engine doesn't come out in the LR procedure.
Hello again,
Where did you buy the turbos? Is there any difference between the BW and Garrett versions?
Hello together,
Thanks LASBAM.
The price was 500,- Euros per each.
| All times are GMT |
