Home > Duckworth Parts > Ignition Switch
duckworthparts
Site Sponsor
Just best to PM your vehicle details, or post what model year on here and i'll price up You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #418792 20th Dec 2016 1:10pm
Sharpy1980
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I also need to replace this switch so have emailed you Dan for current price
Cheers
Post #435842 24th Apr 2017 11:46pm
Judo
Australia
For what it's worth, I had the problem intermittently for at least a few weeks before ordering the new switch. While the switch was in transit mine failed entirely and I couldn't get it to start. Luckily I was at home. I pulled the switch apart, cleaned the contacts, refitted and it's been perfect ever since (4 months or so). The new switch is now a spare for later... So if anyone is desperate, you can definitely clean it. Whether it lasts as long as a new one, only time will tell! -Justin
2006 Vogue Td6
Post #435843 25th Apr 2017 1:27am
Judo
Australia
P.S. Of course if you can get a new switch before it fails, that's probably the best way to go. Smile -Justin
2006 Vogue Td6
Post #435844 25th Apr 2017 1:28am
Sharpy1980
Thanks Dan for the swift service as usual, it came Friday and I fitted it yesterday and it's sorted it, I was tempted to clean the old one out but although it's not too difficult to replace it's not a job I would like to keep doing so now it should see the car out and for £99.50 imo it's not worth getting stuck out Thumbs Up
Post #436448 30th Apr 2017 9:56am
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Dan,
I have a starting problem with our 2006 MY td6, sometimes it cranks over fine but there are no ignition lights showing, so I guess no fuel pump feed. Occasionally it will start fine. It seems like the ignition switch is a common failure, so I suspect it might be the culprit. Could you give me the current price for a new one, please?
Glen.
Post #450953 15th Sep 2017 12:10am
mikomese
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Ignition switch
Ignition Switch current price please posted to Leeds
Thanks Jon
Post #476073 17th Apr 2018 2:28pm
PIMCO
Norway
Hey, Judo. Thought I'd check in with you what the status of this was. I have the same symptoms you had and tried the same fix to no avail. How long did you find the switch to last after the cleanup?
Post #489946 25th Sep 2018 8:14pm
