Home > Maintenance & Mods (L322) > Windows won't raise or lower? have a look at this...
Ollie7195
England 2005 Range Rover Vogue Td6 Barolo Black
Hi everyone,
Had a problem with my range rover since I bought it, both the rear windows wouldn't work!
luckily the rear drivers side door the connector had not been plugged into the window regulator! easy fix...
not so much with the passenger side though...
I could hear the relay clicking for the rear window from both the driver door switch and the passenger door switch so assumed this was fine, checked the connector alas it was plugged in not an easy fix! initially swapped in a new window regulator unit as I had 2 supplied with the car as the rear windows didn't work, plugged it in....nothing Big Cry then tested the old one with some wire direct to the battery...it worked!
ok so the window regulator worked the relay clicked so what could be the problem?
put a voltage tester on the end of the connector 0V when the switch wasn't touched and a flicker of 0.1V when using the switch...interesting
did a bit of research turns out the relay for the windows is under the passenger seat...4 bolts later tilt the seat back for easy access under a flat black panel and here's the box (the little white bit with the 3 connectors)
undo the 3 connectors and the box will pull out it's a bit of a squeeze
this is the Body control unit (BCU) it controls all sorts in the car that you wouldn't expect it to...anyway
here it is removed:
pop open the back with a screw driver then to remove the circuit board push on the white connector and using a screw driver push in all the little tabs on the connector blocks working your way along to the larger black connector, this one doesn't have tabs but a good firm push and the board pops out!
it seems to be covered in lots of anti oxidising gooey stuff that makes it all shiny!
the 2 longer black boxes are the rear window relays, there are 2 separate relays in each black box one makes the window go up, the other down
here's a close up of them:
shiny one is rear drivers side dull one (replaced) is rear passengers side
now to diagnose the one that's the problem...
from the back these are the 2 relays:
then the parts of the relay:
now from this each relay block has 2 relays (2 coils, 2 12V commons, 2 normally open contacts N/O & 2 normally closed contacts N/C)
when measuring put a voltage tester set to ohms on the 12V common pin and to the corresponding N/C pin you should get a very low reading >1 ohm then the 12V common to the N/O pin should be open circuit
also the relay coil should be around 240 ohms
The problem with mine was the N/C pin to 12V common was reading ~60 ohms and wasn't switching (probably stuck/broken) on one of the parts of the relay everything else appeared fine
part you need is a: TYCO V23086-C2001-A303 can be found on ebay for around £5 much cheaper than a £150+ replacement BCU or repair!
the board is a pretty solid one unlike other types I have come across and isn't easily damaged by heat from the soldering iron, I had mine set to 350 degrees c and allowed all the solder around each pin to fully melt before using a solder sucker to take it away this way the relay is easily pulled away from the board afterwards.
not a lot else to say obviously done at your own risk! but it certainly isn't a difficult job Thumbs Up
Another thing to note if this box is unplugged from the car you CANNOT lock it and probably can't drive it due to the different systems it controls so if you plan on doing this you will not be able to use the car during the process...
If your windows are stuck up/down or you need a way to test them without taking the door appart (bit of a pain) you can test them this way...
On the connector on the back of the BCU there are 4 wires that go to the rear windows Blue w/purple stripe & Black w/brown stripe is for the rear drivers side window Blue w/light grey stripe & Black w/green stripe is rear passengers side
looking at the connector this is pins 2 & 12 (rear drivers window) 5 & 15 (rear passengers window)
Hope this helps someone Smile
Post #435906 25th Apr 2017 9:26pm
alistairh
What a cracking write up! Thumbs Up
Post #435910 25th Apr 2017 9:43pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Thumbs Up 10/10
Post #435926 25th Apr 2017 11:29pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Thumbs Up Thumbs Up Thumbs Up Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #435944 26th Apr 2017 9:40am
mr_spock
This should be in the wiki!
Post #435949 26th Apr 2017 10:18am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Excellent write up!! Just so you know the BCM has no direct control of the front windows, the front door modules control the front windows, the BCM just controls the rear windows directly.
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #436027 26th Apr 2017 8:33pm
Ollie7195
Thanks for that Matt will edit the post, annoyingly not more than a week after fixing the relay for the passenger side the rear drivers side also decided to fail!!!! typically stuck half down just as it started to rain Censored got a bit of wire and connected them to the jump spots in the engine bay then unplugged the connector found the rear window wired and powered it my self!
Definitely recommend replacing BOTH relays at the same time as the other will no doubt fail!
Post #436459 30th Apr 2017 11:49am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Great write up, my rear drivers side has been temperamental depending on the weather, sometimes it works, other times you just hear the click of the BCU.
Might strip the doors down to see if the window regulator works off a 12v battery. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #436476 30th Apr 2017 3:46pm
Ollie7195
Tom, saw your post, have been through the pain of stripping the rear doors, can be avoided by the extra bit i've added at the bottom
Post #436478 30th Apr 2017 4:24pm
Flashman
Thanks Ollie, great info! Tom
Current Drive
Previous Drives
Post #436479 30th Apr 2017 4:36pm
