![]() | Home > Maintenance & Mods (L322) > Been told I need new gearbox |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Have you replaced the temperature sensor on this gearbox yet? Alex
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 ![]() ![]() |
No |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Have they not looked at rad and gearbox oil cooler before the diagnosis telling you to get a new gearbox? Surely if there's an overheat warning coming up that would be the first investigation? |
Not that am aware of. How would they know the bands are worn? |
I presume they drained the gearbox oil? |
Would that then show particles in the oil? Am yet to go pick the car up. Obviouslu not havong a new gearbox fitted till am sure of what's going on especially as it's been working ok. |
Yes. Burnt oil and swarf would be in it |
Ok. Got range rover back. Nothing has been fixed. Just charged me the diagnostic fee.
Good idea cleaning the switch yourself |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3228 ![]() ![]() ![]() |
Even if the radiator was changed, if they didn't change the oil cooler at the same time then this could account for the transmission overheat. It is sometimes caused by the lower part of the radiator (where the oil cooler is) being silted up.
If I were you I would find a different garage.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
So you sent your car to a garage.
Hi. Just had a quick look atvthe iid tools on eBay, they look fairly expensive.
