Home > In Car Electronics (L322) > No sound from speakers etc
rattly
Hi all,
Sound from my radio etc has been a bit on and off the last week, now nothing at all!!
Am I right in assuming that this is controlled by the large black amp in the boot?
I changed this a few months ago as I pinned my old one down to the cause of my battery going flat after a few days (boot is bone dry, ie no leaks!).
No more flat batteries, but the pins on the replacement one were a bit "green", I cleaned them up with contact spray at the time, and have just done so again.
If it does do the sound then I guess I`m going to need another one!
All help appreciated,
Cheers,
rattly
Post #436362 29th Apr 2017 4:57pm
I would try switching the radio on and then wiggling the speaker cable plugs on to of the dsp, black box, and see if your radio comes back on. Mine did when I had the same problem, just cleaned all the plug and socket connections and every thing came back to life and been ok since.
Post #436373 29th Apr 2017 6:33pm
rattly
Hi,
Is the dsp the amp that I have changed previously?
Someone else has also mentioned the BM54, the small silver box.
Either way I`ve done the wire wiggling on both to no avail.
If the dsp is the amp then it looks like I need another one!
Cheers,
rattly
Post #436452 30th Apr 2017 10:36am
mjdronfield
The DSP is the black box nearer the rear light.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #436457 30th Apr 2017 11:40am
miggit
Turn the ignition to position 1 (AUX) and look at what's listed of the screen , with the radio off!, in the list you should have DSP... From memory it's on the left hand side 3 row... If it isn't there then it's gone pop again Shocked
 Yesterday I couldn't spell Engineer... Today I are one!
Post #436674 2nd May 2017 12:59am
rattly
Brilliant, I`ll have a look.. sods law its working today, but at least I know what to look for later.. Cheers, rattly
Post #436716 2nd May 2017 1:05pm
Sharky1168
Amplifier repair
Mine isn't the DSP just the HSE (standard?) Lear Amplifier which decided not to work. After searching for a replacement, which are quite pricey even on eBay, I found a guy who repairs them & whilst £80 isn't as cheap as doing the repair yourself, but with my soldering skills, well worth the extra! Current RR L322 TDV8 VOGUE
Past: RR L322 TD6 HSE, Discovery 2. Land Cruiser V8, Saab 9-7x, Nissan Maxima, Ford Granada I, II, III
Post #437209 5th May 2017 9:59pm
rattly
Hi,
Thx mate, all info appreciated.. hasn`t played up since!!..Typically!!
Post #437214 6th May 2017 12:10am
miggit
Whistle Typical 'ang' 'over ... now that your on to the fault it'll go away... It'll be thinking up a new wheeze to worry you with Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #437235 6th May 2017 11:17am
rattly
Funny you should say!!!.. radio hasn`t played up since, but display has gone now!. is it the same unit playing up??
All help greatly appreciated!
Post #439876 28th May 2017 1:53pm
