Home > Technical (L322) > REAR HUB AND SPEED SENSOR PICK UP HELP NEEDED
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I have been trying to track down an issue with HDC and inactive suspension faults, I think it is originating from the left rear wheel.
Yesterday I reversed out from a car park and there was a very loud noise, almost like a bang, grinding noise, I then had no acceleration, it was like the brakes were locking on and preventing me driving over 5 kph. There seemed to be a thumping noise coming from the REAR left wheel. UI had a friend follow on foot and he confirmed the noise was from the left rear wheel
This later cleared and I was able to drive it home at normal speed. I removed the rear wheel today and it was hard to get off the studs, it seemed to be seized, a bit of banging released it.
I removed the brake caliper and disc, The hand brake shoes has a few cracks going through them, These will need replacing, but I don't think it was a hand brake shoe stuck and binding that caused the problem.
I re assembled every thing, and replaced the Rear left hand wheel ABS sensor. .
I then reset all fault codes and went for a test drive. immediately the suspension & HDC warning lights csme up, The speedo was also now showing I was traveling at 160kph when I was traveling at approx 60kph.
So I'm starting to lean to the cause of my ongoing problem is coming from the left rear wheel.
I had a look in micorcat at what parts are in the hub.
I see there is a Knuckle in which the wheel sensor is inserted, a bearing, a circlip and the hub.
Question I have is where does the sensor get it's pick up from, there does not appear to be any reluctor to pick up a signal. I googled pics of the hub and there doesn't appear to be a reluctor on it? , the Knuckle just appears to have a bearing inside, so I am lost.
I feel I will have to pull the hub off and investigate further.
Post #436455 30th Apr 2017 11:26am
mjdronfield
There should be a reluctor ring. Mine rusted through and I had to buy a new drive shaft. I then found out that one from an X5 should fit. Think you can get them on eBay or the like.....if that's what you find it is. The speedo is fed from the rear left wheel, as you prob know.
http://www.fullfatrr.com/forum/topic20879.html?highlight=reluctor 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #436456 30th Apr 2017 11:38am
lounge_on_wheels
Thanks, now I know where the reluctor ring must be, I will swap the sensor again to see if the new sensor is not the problem before I start the major strip down.
Post #436470 30th Apr 2017 2:38pm
lounge_on_wheels
update, the rear speed error is being caused by wrong sensor supplied, it should be SSF000021 and was supplied SSF500021 which is the from 06 models.
Post #436556 1st May 2017 12:01am
lounge_on_wheels
update, the rear speed error is being caused by wrong sensor supplied, should be SSF000021 and was supplied SSF500021 which is the from 06 models.
Post #436557 1st May 2017 12:05am
