Home > Maintenance & Mods (L322) > Coolant O Rings
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Coolant O Rings
Took my motor back today because of a coolant leak after they changed the thermostat. They say it's an O ring on one of the hoses that split when removed. They replaced it but obviously with the wrong size. New one won't be here until tomorrow.
Question is, what sizes are these and are they available as a set to keep at hand?
Post #436723 2nd May 2017 2:49pm
when you get the invoice it should have the size on it ,if not ask the service manager .. ... - .- -.
Post #436728 2nd May 2017 3:18pm
rodp
Garage doing the job says the dealer doesn't sell them separately, only with the hose or fitting? true or false?
Post #436729 2nd May 2017 3:20pm
done a search for you and found this, might help,
http://www.fullfatrr.com/forum/post72757.html#72757 ... - .- -.
Post #436730 2nd May 2017 3:24pm
rodp
Ah, did a search but came up with nothing. Mine's TD6 would they be the same O rings do you know?
Post #436731 2nd May 2017 3:31pm
no i don't know....i don't suppose there's any thing in the WM ? ... - .- -.
Post #436737 2nd May 2017 3:49pm
....or microcat.. ... - .- -.
Post #436739 2nd May 2017 3:59pm
rodp
Finally got through to dealer, O rings not available separately through land Rover. I do notice though that britpart list some, at least the ones in the link you provided.
I dislike Britpart immensely, but may have to order some just to get the sizes for good ones.
Post #436740 2nd May 2017 3:59pm
rodp
Not got a manual, downloaded the rave manual but can't make top nor tail of it. Nothing listed as per vehicle, just lots of random files with no indication of what they are.
Edit to say downloaded the pdf version so can open that one. No mention of O rings though, just shows complete hoses.
Post #436744 2nd May 2017 4:11pm
