![]() | Home > Technical (L322) > I've been an idiot! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Can you not access the backup? When you first start the tool it backs up the settings.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6788 ![]() ![]() ![]() |
I'm going to PM Patrick and hope he's online.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35693 ![]() ![]() |
check the pins aren't bent in the obd port Alan... ... - .- -.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Can't quite remember but is there not a setting you can access even before it links to cars ecus which will take the iid tool back to the configuration it started on..? |
when the iidtool is first activated it backs up all the settings, but Alan says that he cant connect to his FF so he cant use the backup.. ... - .- -.
All great suggestions but when I try to connect the tool to the car, in the logs it says "VIN NOT DETECTED", so I can't get back to the point where I could restore from a CCF backup. It was a restore from a previous backup that I tried, after I had some errors after I had made some changes. Got - 2017 SDV8 Autobiography in Loire Blue
try reloading the firmware onto the iidtool Alan... ... - .- -.
Just doing that as we speak Stan Got - 2017 SDV8 Autobiography in Loire Blue
Aah! Gotcha. Not good, hopefully it's an easy resolve |
Got Patrick on the case |
is he doing it remotely? ... - .- -.
Currently just done the update, but no difference. That could be the next move. Got - 2017 SDV8 Autobiography in Loire Blue
Just a quick update. Patrick had been his usual stellar self and we now have the car and the IIDTool talking again. The next move is to restore from a CCF backup but since my battery's nearly flat, that will have to wait until the morning.
