![]() | Home > General > 3 beeps...?? solved |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Hi all,
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Sure this has been asked before, I think it's either some form of tracker, or if it's almost on the hour, the clock beeping at you to tell you. 2006 Mercedes CLS
did the car come with two black credit card size plastic fobs, this is what the unit in your car is looking for,hence the 3 pips. not found.. V8 facelift Range Rover Autobiography 22" wheels.
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
3 pips is telling you it has a Navtrak Tracker and the little plastic fob is in the car and the system is activated. 5 beeps tells you it has the system but it either can't find the card or the system is deactivated.
def not got any plastic credit card type affair with the car.. Can't recall if it was three beeps but think it was.
Call Navtrak / Cobra on 08000 719800, give them your registration and explain the issue and they will soon tell you if it has a tracker. |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
Is your car garage-parked at night? It's not your outside temp warning beeps going off is it??
My daily "low temp" indicator is a single "bong" rather than a "beep"...
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
LOL so true! |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Do you press and hold access mode to lock it in? If so you will get as you describe once reaching the predetermined speed. Ian |
Thanks for all the suggestions folks.
