![]() | Home > Technical (L322) > Rear wheel speed sensor circuit open |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
ABS speed sensor either broken, or reluctor ring rusted away and not doing its job anymore .
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
Hello again, still no joy with my suspension problem. I lifted the back and removed the wheel arch lining to see better, removed the sensor easily, unpluged it gave it all a clean, nothing noticable, looked like new.lol then while under the car i noticed the left tire looked a bit worn on the inner edge, on a closer look i could see wire |
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 ![]() ![]() ![]() |
I have this problem at the moment.
Let us know how it goes, my sensor looked like new, and a new sensor her in the nanny country is big dollars |
So did mine!
PM me with the cost , not urgent but you know how painful it is to have something that doesn,t work, thanks for the offer, are all thesensors the same except for the length of the connector? |
No idea.
Yes that seems to be the correct sensor, |
Postage is £9.55 according to Royal Mail. They think it's also 5-7 working days delivery, which I'll take with a pinch of salt.
Wow thanks for that, how can i get the funds to you, or can you send receiver pays. Don,t want to cause you too much hassel. |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
yes putting the wrong later model sensor in the rear left wheel added 100kph on my speedo speed when I was only doing $60kph! LOL |
The plot thickens, today while driving at about 50kph i applyed brakes and got a loud grating sound from the front and BONG the suspension inactive and ABS lights were on, braked again , no noise, parked for a while and then when driving home same again, grinding noise when i apply brakes and dash lights up but brakes work as normal drives normal except for suspension inactive and ABS lights. Very unsettling at the least. Any ideas? I will check with my Iir tool to see what faults if any. Thanks ahead of time. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2708 ![]() ![]() |
Why do you not suspect pads worn through? |
The grinding noise is only momentary when the dash lights come on there is no noise and brakes work as normal but no suspension alteration. If was worn brakes wouldn,t it grind all the time? |
