What do you mean by "over time" - minutes, hours, days ? Does it happen only when car left standing (engine off) , or whilst in use?
A couple of things you could try:
Press the settings button to fix the height - see if that makes any difference?
Leave a door open (turn off the lights), or use diagnostic tool to disable the EAS - any change ? (EAS does stay alive after car is switched off and locked)
Valve block for the front is behind the inner wheelarch on the FR (UK drivers side) nearest the door. Worth a look there to see what sort of condition it is in.
If struts/bags are "newish" (how "newish" ?) then problem could be they weren't reconnected properly. in any case, also worth putting in off road height and doing the soapy water and lift test... .
Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember
