![]() | Home > Maintenance & Mods (L322) > Wakey wakey when it comes to starting |
| Diddley Member Since: 13 Apr 2016 Location: Notts Posts: 20
My partner has been using the FF lately and she said when pressing the start button nothing happens. She is new to driving and sits there thinking have I done something wrong. Then about eight to ten seconds later the truck fired up.
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Pressing down on pedal 👍
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
pressing the start button momentarily won't start it if the engine is cold...press for about 3/4 seconds works.. ... - .- -.
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
I've found that sometimes even with footbrake pressure , the car still says press the brake to start. One of those annoying "foibles" of JLR ownership. Also if you whack it straight into drive immediately after starting , it will often shut down again. |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1883
There is/was a software update for that, Steve |
Oh aye, how much?? |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
I'd say a short delay is normal, the diesel glow plugs are warming up before the engine is turned over. But 8 to 10 secs sounds longer than I get, even on cold mornings, so maybe a diagnostic check helpful? Only Range Rovers since 1988 |
| dpm Member Since: 14 May 2018 Location: grimsby Posts: 48
Diddley, did you resolve this problem as mine does this also. Or anyone have any idea why it happens. |
| scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391
its a mysterious gremlin with no explanation. a 10 minute battery reset always does the trick for me.. I've started carrying a 10mm spanner with me |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
^ Fitting a battery isolator switch is easier than continually undoing a battery terminal. |
| TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 129
Mikey how do I tell if I have had the software update? Do you have to rely on the main dealers to get it done? 2011 4.4 TDV8 Vogue SE 1993 Discovery 1 3.5 V8i |
So is there an update or fix for this as it is really annoying |
| nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 109
It maybe due to the system waiting for the glow plugs to warm the engine. What doesn't kill you is just bidding it's time. |
