Home > Technical (L322) > Torx Sizes?
GGDR
Torx Sizes?
Hi guys,
Starting to undo this and that on the Vogue and finding LR seem to have shunned phillips screw heads completely.
I already undid the A-pillar cover to run a wire, that uses a pretty big Torx size. Problem is I wouldn't know a T4 from a T20.
Found a set with the following:
9 x TX STAR: T4, T5, T6, T7, T8, T9, T10, T15 and T20
Will these sizes do most jobs?
Thx!
. Cheers, Greg
Post #437079 4th May 2017 7:26pm
Discotigger
Hi,
You would be better off getting a set that goes from T10 to T50, T10, T15, T20, T25, T27, T30, T40, T45 and T50. This will cover the sizes used on the FF for all usual jobs.
I have a set of Torx keys, but also got a set of 1/2" Torx Sockets, as some of the Torx Bolts are a sod to undo with the key alone.
Post #437082 4th May 2017 8:20pm
GGDR
Amazing thx Discotigger
. Cheers, Greg
Post #437114 4th May 2017 11:52pm
mzplcg
Emphasis on the T27. It might seem odd in the sequence but there are loads that size.
I bought a set of Wera Kraftform screwdriver style ones which are awesome. This set has some and the seller also ordered me the remaining ones at a decent price.
http://www.ebay.co.uk/itm/171919983241?_tr...EBIDX%3AIT
Also worth having a set of 3/8" socket drive ones to get the really tight ones started. Halfords Pro seem to be excellent value.
Post #437121 5th May 2017 7:11am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Torx is the BMW offspring.
I bought a 1/4 inch drive kit with all sorts of Torx and other bits, use it all the time, great for interior and removing wheel sensors, brake disc retainers.
Post #437126 5th May 2017 8:29am
