![]() | Home > In Car Electronics (L322) > Clock wont stop ! |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi Rosco, Have you tried a battery disconnect ? Just today wife came home with the radio stuck on and would not reset with the iid tool, all sorted once the battery was re conected......
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Hi Simon, did try that one, hasnt helped unfortunately, thanks for reply |
Alfasprint88 Member Since: 19 Dec 2015 Location: Kapiti Coast Posts: 25 ![]() ![]() ![]() |
When you watch it do you feel like a time traveller? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35845 ![]() ![]() |
not sure which fuse it is Rosco but pulling it resets the clock according to a previous thread...looked in the WM ? ... - .- -.
Have found a fuse diagram that indicates fuse 13 in the glove box, will try that one |
Sharky1168 Member Since: 21 Jul 2015 Location: Rochdale Posts: 23 ![]() ![]() ![]() |
Had a similar thing happen to me, so pulled fuse 13 for a few hours & put the battery on charge. Not sure if the charge helped, but when I put the fuse back in the clock was behaving itself again! Gremlins!! Now that I have replaced the head unit, the clock has a mind of it's own with no way to set it, BUT it doesn't go round like a bat out of hell anymore Current RR L322 TDV8 VOGUE
