![]() | Home > Maintenance & Mods (L322) > GOOD RADIATOR BAD RADIATOR?? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
Hella is OEM, and fitted to the ffrr in the factory... so if you can get one at a reasonable price, you'll be guaranteed a straight swap and easy fit |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
And fit a 140kPa reservoir cap, not 200kPa. Ron B. VK2OTC
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6430 ![]() ![]() |
I fitted a nissen one for my TD6, no problems with it, only issues being it had no drain tap, so gets a bit messy when needing to drain down, and if I remember correctly (although this could have been the condenser replacement) fixings for the fan shroud were a bit different. Fact is, as a radiator, it works. .
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3269 ![]() ![]() ![]() |
Go for hella - They are OEM as outlined previously but are known to be better quality. Avoid First Line. |
innsanes Member Since: 28 Apr 2017 Location: Socal Posts: 13 ![]() ![]() |
Thanks a lot guys. I'm new to the forum but everyone is so nice and responds better than rangerover.net forum |
^^ Tell me about it!! I've been ostracized to there |
How long should a radiator last? |
About 10 - 15 years depending on what type of water and antifreeze has been used... needs to be deionised water, and antifreeze must be ali compatible... get it wrong and they can clog up very quickly |
