Home > Maintenance & Mods (L322) > Stripped fill plug( gearbox)
alistairh
That's a huge help Phil. I did wonder why it was like that.. gives me a better idea of how to tackle it today . Thankyou...
Post #437638 9th May 2017 10:14am
holidaychicken
As mentioned earlier, I have hammered a torx or spline bit in before to undo rounded Allen bolts
I also always have a supply of the reinforced cut off wheels for my dremel which are great and as a last resort you could use them to remove the bit of casing shown in Phil's photo and then mole grips.
I think if the torx bit failed I'd be mig welding it in place or suck the oil out from the top using an oil vacuum thing.
Post #437731 9th May 2017 8:22pm
alistairh
I've ordered a 9mm spline socket. Will try that once it's here. It's my mates fatty and he's blaming the last owner for rounding it.. I don't believe him. Reckon he's been dabbling again lol..
Post #437735 9th May 2017 8:30pm
holidaychicken
Good stuff, i was thinking your drain plug was engine and not gearbox which is another thread I am sticking my oar in so I don't think sucking the oil out from the top is a good idea unless you want to drill a hole in your floor Embarassed
Post #437895 10th May 2017 5:49pm
alistairh
Success! Rammed the spline in and it cracked.. gearbox serviced.. oil was really dirty looking.. there was swarf on the magnets.. is this normal or to be expected of a 12'year old car?
Post #437904 10th May 2017 7:28pm
holidaychicken
Top job.
Mine had a fair bit of magnetic fluff but turned out to be ok when we stripped it down but RRPhil is you man for that question of course, he can probably tell you what blood group the bloke that assembled the transmission has Smile
Post #437917 10th May 2017 8:46pm
RRPhil
Well done on getting the filler/level plug out!
If those magnets have never been cleaned before then you have nothing to worry about.
This is when you need to worry :
Phil
Post #437998 11th May 2017 2:33pm
alistairh
It's the gearboxs first service so delighted with that. Glad they weren't like that.. thanks for input gents Thumbs Up
Post #438004 11th May 2017 2:51pm
alistairh
Only concern was only being able to get 5 and a half litres back into box ? I did the service as documented?
Post #438006 11th May 2017 2:53pm
RRPhil
As long as you had the engine ticking over and the fluid was at 40°C when you set the level then 5.5 litres should be fine. The torque converter and valve body assembly retain a lot of fluid when the sump is drained. Are you concerned because you drained more than 5.5 litres out, or because you’ve read that the transmission’s capacity is nearly 10 litres?
Phil
Post #438020 11th May 2017 4:11pm
alistairh
Hi Phil. I was only concerned as I had misread it would take 7 litres. I presume the 10 litres is from dry? Would you recommend maybe draining another 2 litres out after a certain amount of miles and refilling with 2 litres fresh fluid? Ta
Post #438028 11th May 2017 4:55pm
I did a calculation once. Mathematically you have to do @ 5 changes to "change" 99.99% of the oil
Cost @ £90 if you buy in bulk. .
Post #438029 11th May 2017 5:37pm
