Home > Technical (L322) > Light whine at 80mph
Sandyt
Gents as stated above on a 2007 4.2 I am getting a light whine at 80mph whilst under load it disappears at 70 and over 85
Gear change doesn't change it so it is purely speed related so thinking drive shaft or diff any ideas anyone
Post #422636 13th Jan 2017 10:05pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Is the wife in the car? Whistle Twisted Evil
Post #422647 14th Jan 2017 12:12am
Sandyt
Not when it is a light whine but certainly when it is loud through the range Smile
Post #422649 14th Jan 2017 12:21am
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Re: Light whine at 80mph
Unnecessary quote removed
Sandyt did you get to the bottom of this?
Post #437891 10th May 2017 5:31pm
Sandyt
Nope it is still the same and another 8000 miles in so who knows?No faults found and drives absolutely perfect
Post #437928 10th May 2017 9:37pm
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
My 2011 did the very same thing. Turns out there was a service document pertaining to the transfercase chain micro wear on certain l322 / D4's and within a certain vin range 2010-2011 production being a factory / production tolerance fault issue.
The whine was not loud, only vaguely audible under load between 100-120kph.
JLR replaced the chain under maintenance plan approx 10K km ago, been perfectly quiet ever since...
I dont know of my transfercase is the same as yours, i know they were changed to different models during the L322 production.
Who knows, just maybe its the same issue materialsing in yours..
Post #440561 3rd Jun 2017 9:28pm
Sandyt
Interesting thanks for the info will have a look thinking of putting on a four post ramp and running up to see if I can hear anything
Post #440586 4th Jun 2017 10:33am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Just swap to a Barolo and slow down a little so you don't spill any. You'll be fine. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #440635 4th Jun 2017 4:01pm
dan_uk_1984
If it goes when you lift off - it could be the rear diff. An oil change of the rear diff should be done every 80K
Post #440636 4th Jun 2017 4:20pm
marcochezzi
Service bulletin LTB00498NAS1 regarding the transfercase whine attached, yes its for later models, but still maybe worth a look...
EDIT - Cannot seem to upload PDF's, and the image quality on the thread is too bad for visuals, anyone know if I can upload PDF's??
Post #440898 7th Jun 2017 2:56pm
Mightymarcos
Mine was the same although around 70-75 was peak whine. I changed the transfer box oil for new factory oil and it got no worse over nearly 40k miles. Taking a rest from Land Rovers for a bit.......
Post #441083 9th Jun 2017 6:00pm
