Home > Maintenance & Mods (L322) > 4.2 SC Pads & Discs
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
4.2 SC Pads & Discs
Evening gents,
Time to do all 4 corners as far as brakes are concerned.
I understand from doing a few searches, that a lot of you just got for the genuine LR discs+pads and call it a day. Just wanted to know if this was still the done thing? What discs+pads do you have on your SC?
I tried banging my plate into eurocarparts.com to get some prices just as a reference point but there is a few different sizes and not sure what fits the SC. I think its probably 360mm diameter front and 354 rears?
Thumbs Up Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #437929 10th May 2017 9:49pm
i had problems with after market pads and discs on my old SC and finally went for OE from ducky dan..its not worth the hassle putting cheaper stuff on.. ... - .- -.
Post #437930 10th May 2017 9:56pm
Rafterman
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
I replaced my discs and pads last year,got them from ducky dan and not had any problems at all. Very Happy The worst thing about being retired is you miss out on all the bank holidays
Post #437932 10th May 2017 10:21pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Did my fronts a couple of years ago and my rears last week. Used Advanced factors. (Brembo for fronts with Borg & Beck for rears). Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #437969 11th May 2017 10:41am
mandelbug
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I got Brembo discs and pads from EuroCarParts the other weekend when they had upto 55% off. No issues with them. Came in at £170 after the discount
Post #437981 11th May 2017 12:19pm
JPHC
Thanks guys. Might have a shop around Thumbs Up
Mandelbug: What size did you go for off ECP? I get the option of 344mm or 360mm fronts and normal or vented rears?
Dont know what fits the MY07 specifically. Jordan
'56 SC 4.2 ‘16-‘18
Post #438017 11th May 2017 3:29pm
I replaced the whole lot on my SC last year with Brembo pads and discs from Advanced Factors.
There has been talk previously suggesting that Brembo do not make these brake parts, but I have checked very thoroughly and they most definitely do.
So, I'd search for genuine Brembo parts or go straight to Dan at Duckworths for OE.
Importantly, do not forget to get ceramic grease for the pads. I gather it's far better than copper grease for this application. Advanced Factors supply this as I'm sure will Dan. Si. <This is my name.
Post #438021 11th May 2017 4:26pm
mandelbug
360mm fronts. Not done the rears as they were done before I bought the car.
Post #438100 12th May 2017 7:40am
