Home > Maintenance & Mods (L322) > Jack which can lift the full fat wheel off the ground
Page 2 of 5 <12345>
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
do you think a td5 disco bottle jack would do ?
Post #437894 10th May 2017 5:42pm
nino_nino
I am using one with a piece of 4"X6" under for added height
Post #437902 10th May 2017 7:20pm
miggit
Whistle you've obviously never jacked up a ffrr....cos they go on and on and on... and just when you think it'll never lift the wheel off the ground it finally does.. And for all you ffrr jacking virgins take our word for it rather than put it to the test... jacking up a ffrr with either a 2 stage bottle jack or the factory jack Shocked is not something that should be done for fun, only in an emergency, and as a last resort Yesterday I couldn't spell Engineer... Today I are one!
Post #437947 11th May 2017 8:22am
naks
South Africa
even if you jack it up under the suspension arm?
this is what I used to do on the D4, worked perfectly (this photo doesn't have the block of wood).
 Discovery 4 Workshop Manual: http://bit.ly/22l8YHh
Defender Puma Workshop Manual: http://1drv.ms/1nNpJeM
Range Rover/Sport Workshop Manual: http://bit.ly/2iH7jgG
Post #437958 11th May 2017 9:15am
miggit
That's not the safest option, it only takes the suspension to have one of it's little paddies and it'll pop off the jack.... if you use a high lift (2 stage ) bottle jack in the jacking positions on the sill it is held in place... I'd only use my trolley jack to raise a ffrr at that point cos the cup is 100mm dia and it also has a rubber insert for added grip Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #438061 11th May 2017 9:04pm
nino_nino
Rik, td5 jack is perfectly ok, have used mine on td5 since the year 2000 and on the ffrr for the past two and it works great. here are pictures of the jack i use. Notice that head of the jack is made to fit cars lifting point to prevent movement.
and for your question, rodp, this is the way I store my.
Notice I removed original jack and am using space for jack stand.
hope this helps.
O, and for the whistling guys, they are mostly whistling dixie Very Happy
Post #438155 12th May 2017 1:44pm
rik
perfect will put in car. have only jacked up car with trolley jack about 100 times at least. don't want caught out although I am with the AA I never needed them for flat (yet) especially with lpg so room for spare is not possible .
Post #438176 12th May 2017 4:31pm
Clivefog
Ebay seller would not accept £30 offer, almost instant decline, did accept £33.
Arrived today the 15th fast delivery as well!
Post #438202 12th May 2017 7:39pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
dispense with blocks of wood, spacer etc and just get this and have plenty of lift.
http://www.ebay.com.au/itm/New-Mercedes-Sp...SwbsBXlcVh
Post #438571 16th May 2017 10:48am
Les_Paul
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
How about this jack? Just keeping it in the truck won't harm the longevity of the jack?
Pro-Lift B-006D Grey Hydraulic Bottle Jack - 6 Ton Capacity https://www.amazon.com/dp/B00DGXVX18/ref=c...rzbQK9KB2N
Post #441792 17th Jun 2017 5:10pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
@nino.
Sorry, I cannot see exactly what shape the head of your bottle jack is. Is there a specific shape for the RR? Or can I buy the correct shaped head from somewhere?
If so, where please.
Many thanks.
Update: It's OK. I have bought a TD5 bottle jack as per the thread above. Will follow you @nino and use a sturdy block of wood to raise the jack up a bit. Thx.
Post #441801 17th Jun 2017 6:43pm
miggit
NOPE!! it's a single stage lift, the Mercedes Sprinter jacks are telescopic 2 stage, which gives them almost twice the lift of a standard bottle jack. Yesterday I couldn't spell Engineer... Today I are one!
Post #441862 18th Jun 2017 10:14am
nino_nino
Gyre8,
Post #441902 18th Jun 2017 4:52pm
Gyre8
Ah. Thanks, Nino.
Post #441916 18th Jun 2017 6:33pm
GGDR
Any reason why lifting from the suspension arm is not recommended?
Midgets you say it could pop off... Why is that? If another say opposite well is chocked?
. Cheers, Greg
Post #441922 18th Jun 2017 7:05pm
Page 2 of 5 <12345>
