![]() | Home > Technical (L405) > Stealth mode |
| Caddyshack Member Since: 03 May 2017 Location: Guildford Posts: 61
I believe it dims the "mood lighting" so it doesn't look like you are sitting in the car with the lights on...
| AMTony Member Since: 01 Mar 2017 Location: North West Posts: 81 |
Car is fairly dark inside at night so only conclusion must be that mine doesn't work?
| Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584
On my car the Stealth is activated when you turn off the main screen. At that point the speedometer graphics go to the 'torchlight' mode, the temperature readouts turn off and mood lighting is turned off.
Thanks Nick - read something about this but how do you turn the screen off? |
Depending on your spec, there is a power 'hard' button on the bottom left side next to the screen, or it is a 'soft' button om the bottom left of the touchscreen home screen.
Thanks - will press and see what happens |
| bear100 Member Since: 22 May 2011 Location: south wales Posts: 204
Yep, you enable stealth, then read the instructions on the screen! Press the off button on the bottom left corner of screen |
Thanks everyone - never realised there was the image of an on/off button on the screen.
| Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507
what do people think of the overall intensity of the mood lighting, I have mine turned up fully but unless there is something like a cleaning rag in the door cubby reflecting the lights then I can hardly tell its on. this may of course be something I am not doing correctly. :-} Agueroooooooooo. 93-20
| w8pmc Member Since: 30 Oct 2016 Location: West Lancashire Posts: 229
Mine's set to blue & i'd say they're quite bright & certainly unmissable. Obviously in the daylight they're not as easy to see, but in the dark they're very obvious. Paul
| Lutonboy Member Since: 26 Dec 2016 Location: Bedfordshire Posts: 35
I've set mine to orange/yellow and its fairly unassuming even at full brightness. I like it though, fits well with the Almond/Espresso. |
