![]() | Home > Technical (L322) > Coils pack |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 834 ![]() ![]() ![]() |
Or a bad plug.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
No faults on the iid tool, I would have thought it would have shown something. Plugs were new a month prior to doing cam cover gaskets and were fine although they did get covered in oil from the leak and I cleaned them off.. possibly the electrical contact cleaners fouled the plug? I'm hoping the puffing from the exhaust is related to the plug/ coil 👍 |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
Swap the suspect coil to one of the other cylinders and a known good one to the suspect cylinder. If the fault moves cylinder you can narrow it down to the coil. |
Swapped the coils and problem persisted, changed the spark plug and it's fixed.. new plug had only lasted a month and died.. nice cheap fix so happy with that.. thanks for input gents.. |
Good to hear! |
Pleased it was just a bad plug. My grandad used to say start with the cheaper option first and he's been proved right quite a few times bless him.....
