![]() | Home > Technical (L322) > Front Headlights Washer Jets - Not Working |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
I disconnected the line and blew compressed air through it. From this spray came out the nozzels on the bumper. Therefore all is connected right, therefore the only problem appears to be the pump/ or fuse. |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Don't forget that the h/l washers only operate every 5th time the w/s washers do and need the h/l to be switched on before they will operate. |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
I had faulty jets and the mot failed.
Yes, it looks like the pump isn't working for the headlights.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
the rear washer isnt required for the mot... |
You'll also need to swap the plugs, easiest way in is to remove the passenger side wheel arch |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Unnecessary quote removed
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I believe the OP has changed to a newer model TDV8 but hasn't gotten around to updating his profile yet. |
