![]() | Home > Technical (L322) > Low rev misfire |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
get her on the analyser find out which cylinder is misfiring mabe a plug or coil . lpg can be a bit lumpy at times and throw up eml light check all the little pipes for leakage good luck |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Just rectified the same issue after changing cam gaskets.. oil had filled the spark plug well and cylinder 8 was playing up.. easy to check.. start car and 1 at a time unplug coil from connector and engine tone should change. If you get to a cylinder that then note doesn't alter then you have found either a bad coil or sparkplug.. |
Deltaevo Member Since: 02 Apr 2017 Location: Ashbourne Posts: 39 ![]() ![]() ![]() |
Update
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
move coil pack cylinder 5 to a different plug, run car and see if codes move to another cylinder. if it does replace the coil pack.
Thanks I'm going to try swapping the coil tomorrow. |
Update
New coil pack fitted, all's well. |
glad you got it sorted |
Thanks, one thing I am wanting to know is the size of the plug socket, I bought a 12mm but this does not seem to fit onto the spark plug properly, its not a long socket either so I wonder if the rubber inner in the socket is stopping it from going over the plug?
