Home > Technical (L322) > ABS sensor. Have I been an idiot
Keith A
United Kingdom 2009 Range Rover Vogue SE TDV8 Buckingham Blue
So replaced the right rear abs sensor over the weekend and that curred the speed sensor issue for abou 100 miles. However it's now back.
Thinking back to the old one and when I installed the new one there was no dielectric grease on the sensor or the reluctor ring. I didn't put any on either. Do you think this is the issue? I'm thinking yes.
How much needs to be put on? Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Mini Cooper Race Car Smile
Post #438418 15th May 2017 9:38am
GraemeS
Australia
I say NONE because the sensor has to detect the teeth and the gaps between the teeth.
Post #438420 15th May 2017 9:48am
Keith A
LR supply the grease with the sensor. I didn't use it.
Doesn't it work by magnetic detection? And that by removing the electrical air gap that it will get a better connection? Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #438422 15th May 2017 9:51am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Is the gap correct? Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #438424 15th May 2017 10:14am
Keith A
It's not adjustable as far as I can tell. So I don't know. I'd have hoped so. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #438425 15th May 2017 10:19am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Had similar on mine, turned out I hadnt pushed it in quite enough. A gentle tap saw it fully home and its been fine ever since.
Post #438432 15th May 2017 11:01am
Keith A
I'll whip it out again this weekend and make sure all is fully clean again.
It was exceptionally tight to fit, so will try and free up the hole and see if I can get it to sit any closer to the ring. I had tapped it in previously, but maybe it's not far enough in.
Keith Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #438505 15th May 2017 6:55pm
