![]() | Home > In Car Electronics (L322) > Range Rover Bluetooth Retrofit Kits (2003-2004 Rovers) |
In case it might help someone .........
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 ![]() ![]() |
If anyone done this and fancies doing it to my RR I'd be happy to pay |
What happend to 2002 MY?
I've done it - very worthwhile IMO. I'd do it even bearing in mind that a Parrot/other BT unit can be had for around GBP100. Unfortunately I'm a little far away to help you Paul. If you want to come to France... |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Just bought a Gen13 ULF bluetooth module from Germany (complete with rocking horse poo and hens teeth) - Gen 13 (the latest) go for £300+ even so the Bimmernav/RangeRoverupgrades upgrade is expensive but is also the closest to plug and play you will get. I got the modified loom from Adam at l322.com "On first name terms with my local Dealer......now."
nebc100 Member Since: 14 May 2017 Location: Altlinster Posts: 76 ![]() ![]() ![]() |
Hello SteveMFR, I am new here as I have just yesterday bought my 2003 TD6 to keep my Disco 2 TD5 company. My vehicle has thr full Navigation system, phone etc. I know that it has been upgraded (don't know all details), but it doesn't have bluetooth handsfree (only handsfree for the built in phone). What can i do to get bluetooth in the car? I live in Luxembourg, so i can travel if needed. Thanks for your help/advice. Nick |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34972 ![]() ![]() |
this thread is 6 years old so try a search or look in the wiki, there's loads of info re this .. ... - .- -.
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
Hello nebc100
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 ![]() ![]() ![]() |
I re-pinned mine and fitted a ULF. Easy enough with the diagram |
Can you possibly give me more details or a link as i don't fully understand all these electrics yet.
There's a plug dangling in the boot. That's what you'll need to re-pin. It's literally remove a pin one at a time and re-position it.
Ok... That doesn't sound too bad.
You can buy a BMW ULF off eBay. There are several versions - the later the better but then they get more expensive. You can buy a mic and antenna from a BMW quite cheap. The mic already has wiring for it behind the panel in the headlining and clips into place.
Ok... I have been looking... the ulf seems easy enough to find. Considering I have the original built-in phone, am I correct that this ulf will replace the phone module in the boot?
