![]() | Home > Technical (L322) > Coolant query on a TDV8 |
| SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128
Ok thanks for checking I will give it a bleed. |
| Nespouls Member Since: 06 May 2017 Location: Terrasson Posts: 24
Hi Steve,
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204
My low coolant was coming on no leaks at all the thermostat cover was done last year so no air locks,changed the sensor and now finally looks like it's the actual header tank as the float sticks on a lot of jlr models and my mech has done about half a dozen bottles so just ordered a new one so will try to get it fitted beginning of next week as nothing else has a problem i.e. Pressures,pipes all ok _____________________________________________________
Thanks for the replies guys
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
Mine still sits around the min level. If I put more coolant in it just drops to the same level and stays there. ______________________________
New header tank came today so went straight out put it on really easy if you blank bottom hose off when you pull it off used a rag, take two bolts out new one in and save a fortune at stealers then keep topping up went out for an hour with coolant bottle and stopped twice to check all great no annoying 'check coolant level' if you need one try LR trade parts off the bay £35 delivered and a genuine part 👍
That's a good price. I paid £38 inc for the tank and a new cap from Land Rover so similar.
Well after 100 miles over the last 24 hrs and up the toll road and everywhere no issues at all relieved now the annoying bong has gone away and all ok |
Well after a very long time in the garage they have finally got somewhere.
Ouch! |
Some good news. Also it sounds like you got a few new things fitted under the warranty. That will frobably be the last FFRR that dealer sells.
It was the last thing they had to check so they stripped the heads
