![]() | Home > Technical (L322) > Battery replacement in 2011 L322 |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Got mine replaced by a local ATS garage. They removed the scuttle and wipers. Bit of a PITA, but it worked.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
I think the screws are "anti-tamper" screws. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
mikeyyn Member Since: 17 Oct 2011 Location: Notts Posts: 53 ![]() ![]() |
Err, not simple, more recent cars have an ECU in the way with the tamper proof bolts.
I am sure you are right.
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 124 ![]() ![]() ![]() |
I did mine a few months ago and it wasn't too bad. You need to put the bonnet in the service position, disconnect the battery and then disconnect and remove the ecu. IIRC I found it easier to remove the ecu mounting bracket with the ecu. The ecu was just fixed with torx screws. Then undo the battery clamp and lift the battery clear.
Has been tampered with, and new battery installed. FOC from Maltings in Westwoodside not far from Doncaster, recommended.
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 554 ![]() ![]() ![]() |
Hang on a minute! Slightly off topic, but if you can a tool to remove tamper proof torx, they aint tamper proof are they? Drives:
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
Yeah, I bought a set of tamper proof torx bits from machine mart 😁 2004 Vogue TD6 - Remapped |
