Home > Technical (L322) > Odd air suspension problem
smiler289
Hi
I realise there's many posts about the air suspension but thought I would see if anyone has had this happen before and if there is a way I can sort it without goinf to the garage.
Our 02 l322 has been showing the air suspension inactive message for about 2 to 3 weeks. You can't raise or lower the suspension but the lights are still on the suspension controls, they just flash when you try to operate the suspension.
I bought a reset tool but it would not reset the fault. The air suspension still works at keeping the car on it's normal suspension height however.
Well today we get in the car and there's no lights on the suspension controls and the rear right suspension is right down. I used the reset tool and it cleared the fault! I can now raise and lower the suspension but not on the rear right corner.
Anybody know why thus might be? That corner always seams to be lower than the others when we come back to the car and I measured the height on all four corners and they are all different.
Post #439127 21st May 2017 11:02am
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Just a guess but have you checked the ride height sensor on that corner? Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #439128 21st May 2017 11:21am
smiler289
Hi. I haven't no. What should I be looking for? I changed the wheel on that corner a few days ago, although have been having problems with that corner for weeks. I noticed there was a plug with nothing in it and wondered should there be anything in it?
Sorry picture is wrong way round.
Post #439129 21st May 2017 11:30am
smiler289
Ok something interesting has just happened. I drove the ff onto our flat concrete level yard. I pressed the ride height inhibit switch and the rear wheel came to it's correct height, I think the front left moved sown a tad too. Now it all seams to be working and has not faults showing on the dash.
Post #439146 21st May 2017 2:06pm
Dijit
I's run it up to maximum height then drop to access height a few times and see how it performed. Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #439150 21st May 2017 2:22pm
smiler289
I've thought about doing that but now am worried if I do it will mess it up again lol. The troubles started when I put it on maximum height a few times to do work underneath it.
Post #439151 21st May 2017 2:24pm
smiler289
Thought I would just update this thread.
Problem solved.
Needed new height sensor on rear right. This had "apparently" already been done by another garage.
Now all works fine, recalibrated and tracking done, drives much better.
Post #447908 15th Aug 2017 8:53am
