Home > Technical (L322) > Any info on changing a TDV8 3.6L Power steering pump?
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Has anyone changed or seen any info on changing the Power Steering Pump in an L322 TDV8 3.6?
The workshop manual I have for some reason only appears to cover the 4.2L supercharged and all the references I can find seem to to have been dealer changed.
I assume it's done from underneath and would hate to think its as bad as changing the alternator? Please tell me it's simple!!!
Thanks Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #439130 21st May 2017 12:40pm
Mikey
Done from above. Bit awkward and fiddly, as everything is on these cars Laughing
Airbox out, Fan off, belt off, hose clip off and HP union undone, 2 bolts at the front, 1 at the back
Post #439132 21st May 2017 12:45pm
Dijit
Thanks Mikey. So no need to go underneath at all? How long did it take you? I've got the fan and belt off already. Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #439133 21st May 2017 12:51pm
Mikey
It took somewhere between 2-3 hours, but that was my first one
Post #439136 21st May 2017 1:08pm
Dijit
Thanks again. This one drove in and when the owner went to leave there was a puddle underneath and steering was groaning. The reservoir was low and the oil looked blackish. With the belt off the pump has a little movement not the pulley and sometimes clicks when turned by hand. I can't actually see the leak so am guessing it's the pump. Does this sound about right? Btw it appears the oil is only available from LR although I see Island 4X 4 have an alternative at £11/litre rather than £19/litre. Anyone any experience or thoughts on the oil?
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #439139 21st May 2017 1:17pm
rar110
The leak is more likely to be at the rack end on driver side. ______________________________
Post #439194 21st May 2017 9:25pm
