![]() | Home > Technical (L322) > How quickly can fuel go bad? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8062 ![]() ![]() ![]() |
It takes a while to gel - but it could get contaminated almost immediately I guess...... |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125 ![]() ![]() ![]() |
Modern petrol in a sealed container will last for a considerable time - possibly years. The problem is when its put into a cars fuel tank which is vented to atmosphere. Then most highly volatile components in the petrol will tend to evaporate over time. As they do, the remaining fuel's volatility and ability to combust properly will degrade. The less volatile the fuel, the less effectively it burns in your engine. The result is diminished engine performance. Your engine may still start and run, but it probably will lumpy and keep cutting out until the engine has heated up. Ask any lawnmower owner who doesn't drain their fuel tank at the end of the season and then struggles to get it going the following spring.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
I agree.
Phils Member Since: 01 Aug 2016 Location: North west Posts: 71 ![]() ![]() ![]() |
Fuel will go bad over 3-6 months. But bad is a relative term.
Oh and should have said, get some easy start and spray in the intake, if it does not start with that its not a fuel issue. If it does start keep spraying for say 10 secs, once every thing in the carb gets wet it may run on the petrol.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
Thanks for the food for thought gents. TBH we have tried everything inc retarding advancing etc etc and bad fuel is really the last option.
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi ,
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
Interesting, as I've had issues with fuel causing starting issues on my classic cars after about 3 months.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
I have a classic and p38 in the garden neither have been on the road for nearly 4 yrs I move them about once every 6 months neither has had new fuel added and both start after a couple of turns - my guess is water in the carb good luck be interesting to see what the outcome is |
Well new fuel made not a bit of difference |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Have you checked the compression? |
Know it sounds daft but the leads are on the right plugs had a similar issue when replacing coil packs on p38 got in a right muddle and plugged it all up areas about tit
Riedland Member Since: 06 Oct 2015 Location: Far east Posts: 21 ![]() ![]() ![]() |
You mention it's a restoration project, what did you do to the engine? Is the ignition set right? Sounds as you had not the sparks at the TDC. Current: - L322 2006 S/C lpg - RRC 1988 lpg / 287 000 miles - Stage one 1981 - Lightweight 1976 - 109 SW 1968 under rebuilt Gone: none |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
I would take all the spark plugs out and let it stand overnight, it may be flooded, or take the FI fuse out and crank.
