![]() | Home > Maintenance & Mods (L322) > 4.4 M62 rough idle |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
I've dealt with it 3 times since January.. 1st was the rubber seal from the air inlet to the throttle body.. heat had shrivelled it letting in unmonitored air. 2nd was a bad coil pack. Lastly was an injector playing up . Hit that one with some bg44k and it shifted luckily for me.. |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2307
Meant to say two things - i run a cone filter and have done for a year and hasn't caused me issues. Also it is mildly better on lpg.
| Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433
if it's dual fuel does it happen on both ?
how often do you do plugs on these they've bene in about 20k tbh use either NGK-R or Bosch normally can't remember what i went with last time... Oil service was only at xmas but didn't check plugs. it happens less on lpg but it takes a while to warm up to switch over so it may just be because its warmer. also i am convinced sometimes on startup theres a feint smell of petrol under the bonnet... |
Dan.. nothing showed on the iid tool.. all I did with the coils was pull them one at a time with the engine running and when I got to the bad pack the engine rpm never changed when i unplugged it..the other issues where trial and error |
I'm guessing the dead cool made it run rough on driving too which mine doesn't? |
as you can smell petrol sometimes on startup I would suggest the LPG system is becoming blocked up, run the casr purely on petrol for 100 miles everything should be perfect in which case bad LPG or maybe blocked injectors/vaporiser this is a comman issue that some folks don't understand so I will try and explain for everyone LPG ECU takes it's instructions from the CAR ECU, the LPG when running emulates the injector pulses back to the CAR ECU, the LAMBDA sensor reviews the exhaust fumes, as the LPG system is a little lean the CAR ECU increases the injector timing to allow more fuel in (remember the car still think's it's on petrol) when the car now starts it's starting on a worn LPG system an over fueling, this is giving the rough running and petrol smell, after 100 miles the car ECU will reset it's self to run correctly on petrol, than you need to look at the LPG system, cleaned or retuned if thing's have become a little worn over time LPG runs better on single node spark plugs, I would always recommend BRISK plugs which are around £30 a set if you fancy a trip to liverpool I can help with the LPG system I have most software for LPG kits of all brands |
Just ran for 100 miles yesterday on petrol still lumpy on petrol idle fine on gas even after that.
so other possibility is a fuel leak somewhere, check all lines from tank upto front of the car, what LPG system do you have installed? some can be forced to start on gas so you could rule out a cold start problem or a petrol start problem |
Yea I have a zavoli system so I could try a cold start by holding it on a warmer day - also had the tank covers off no obvious leaks didn't go all the way to the front as ran out of time but there were no stains or anything |
you may not get a stain, if the leak is slight dropping the pressure on the rail you pipe would get wet but would soon evaporate leaving no signs, next job check fuel pipe and return pipes tank to fuel rail and back,
Hi all thought I'd better reply - it ended up being the purge valve. Got a quote from lr £105 plus vat ... then gave my part number to bmw £55 all in! That one hell of a markup lr must make...
| All times are GMT |
