Home > Technical (L322) > Black smoke from L322 TDV8
mcj0rdan
I have suddenly become aware that my 2007 L322 TDV8 is belching black smoke when accelerating/kick down. The general opinion is over fuelling??? I have no warning lights showing and there is no lack of performance. On plugging in my IID Tool, the only engine fault code I get is "P023D-22 (6C) Manifold absolute pressure-turbocharger/supercharger boost sensor A correlation-General signal failure-signal amplitude>maximum". I cleared the fault, took for a test drive, car still smoked and fault had returned on rechecking.
Any help would be appreciated. Thank you.
Regards,
Mike.
Post #439717 26th May 2017 5:28pm
Most likely a split turbo hose
If so, the good news is it's a cheap fix & nothing serious
Do a search - there's loads of threads Thumbs Up
Post #439718 26th May 2017 5:31pm
mcj0rdan
Thank you for your quick reply Alistair. I have already had a quick look at the Turbo hoses, I guess I may have to remove them to check properly. Thanks again for your help.
Regards,
Mike. Thumbs Up
Post #439719 26th May 2017 5:51pm
mcj0rdan
Have just removed the right hand turbo hose, and sure enough 3" split!! Thank you Alistair for making me check it properly!
Regards,
Mike. Very Happy
Post #439724 26th May 2017 6:42pm
rar110
That's a weird split. Was it underneath? ______________________________
Post #439731 26th May 2017 9:05pm
rar110
Is the split at the intercooler or engine end of the hose? Thanks. ______________________________
Post #439732 26th May 2017 9:07pm
Glad that's all it seems to be Thumbs Up
Post #439734 26th May 2017 9:09pm
mcj0rdan
It is at the engine end on the top, (a bit obscured by some other hoses.) Will be interesting to see if replacement of the hose sorts the engine fault code. I'm also surprised such a serious split didn't send it in to limp mode!
Post #439741 26th May 2017 10:41pm
Yep, that should fix it.
Where it goes every time seems to be the failure point Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #439746 26th May 2017 11:19pm
nearlee
Wales
Old thread resurrection ......
Can someone tell me where this hose runs from and too, pictures would be great
Thanks Remember:- amateurs built the ark
Proffesionals built the titanic
Post #476227 19th Apr 2018 2:22pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Diagram here: https://www.advancedfactors.co.uk/intercooler--hoses-1949-c.asp
(That's for a 3.6 which is what the original thread relates to - I presume the 4.4 is very similar)
It's the top hoses that are prone to failure.
4.4 diagram: https://www.advancedfactors.co.uk/intercoo...1795-c.asp 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #476232 19th Apr 2018 3:40pm
nearlee
Wales
MikeO
Your a star, yes 3.6 and the nearside has a split in it at intercooler end.
New ones ordered. Remember:- amateurs built the ark
Post #476233 19th Apr 2018 3:49pm
