Home > Maintenance & Mods (L322) > Oil Grade
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Oil Grade
Hi folks,
I know the recommended grade is 5w30 for 3.6 TDV8 but I was wondering if there was any harm using 5w40?
Also where the best place to buy a genuine service kit? i.e. Oil filter, fuel filter etc
Post #439816 27th May 2017 7:45pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
http://www.carbibles.com/engineoil_bible.html
Why would you want higher viscosity?
Do you think the recommended spec trades fuel economy against wear and tear?
Post #439853 28th May 2017 7:42am
scotcruz
Cheers .. I came across that page.. basically from a cold starting point it doesn't make a difference and it's never gonna be 40° in UK.
Just really wanted person experiences of members in the forum
Post #439854 28th May 2017 7:45am
Try Dan at duckworths for service kit.
The 3.6 has a ford spec oil it needs. WSS M2C 913 B. Its pretty easy to come across, and theres no good reason to use anything different, its not an expensive thing to get hold of and is readily available at motor factors and from Opie etc
What is your rationale for wanting to use something different? There is nothing that can't be fixed with a hammer😜😜
Post #439888 28th May 2017 6:10pm
scotcruz
cheers mate..
My rationale is that I have about 20 litres of Miller's fully synthetic 5w40 which I used in my Shogun. I've always bought in bulk and works out cheaper.
it's a good oil and thinking if the hot rating of 40 really makes a difference. In Scotland we hardly get to 30 degrees let alone 40.
Post #439901 28th May 2017 8:35pm
its not just the viscosities which have to be looked at but SAPS levels and lifespans of the oils too.
for example you can get a 5w30 oil which is a ACEA C1 and a 5W30 which is a C3 which aren't the same in terms of performance.
also you can get a semi synth in 5W30 and fully synth in 5w30. again different and will have marginally different wear rates etc for the engine.
Personally would stick with the grade and spec LR specify. Be careful though there are some semi synth oils such as Shell HX which are WSS m2C913b but are a semi synth. they meet the standard set but personally would favour a fully synth. There is nothing that can't be fixed with a hammer😜😜
Post #439903 28th May 2017 9:06pm
scotcruz
yeah.. I'm not a fan of semi synths either.. I've reached out the Duckies for a kit so let's see what they say Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #439907 28th May 2017 9:29pm
Rambles
http://www.eurocarparts.com/ecp/p/car-part...0wodrusK3g
Fully synthetic
Not expensive
Post #439931 29th May 2017 7:48am
Rambles
Higher viscosity will put additional pressure on your oil pump...
Will reduce MpG
For newer engines with finer tolerances you need less viscous oils...
Post #439932 29th May 2017 7:49am
scotcruz
Cheers Rambles.. Im not a big EXP fan but have ordered a 20L drum for the correct spec recommended be big monkeyjones Current:
Past:
Post #439988 29th May 2017 3:54pm
