Home > Technical (L322) > Heated steering wheel operation
dirtymonkey38
Hi, been to look at a 2010 4.4 tdv8 range rover over the weekend. Tried the heated steering wheel out but didnt seem to do anything when I pushed the button. Is there any indication that it has been turned on such as and led lighting up? Just want to make sure its not a fault.
Post #439921 29th May 2017 3:21am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Mine has a red LED light up when on. It is a 2006 MY so things could have changed but hopefully that is some help. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #439922 29th May 2017 5:41am
a light does illuminate when its pressed... ... - .- -.
Post #439924 29th May 2017 6:07am
Baltic Blue
The switch lights up, but mine is like me, a bit dim !!. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #439927 29th May 2017 8:23am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Agree on the dim light post 2010 - can't see in bright daylight. It heats up within a minute or two. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #439933 29th May 2017 9:09am
dirtymonkey38
Good to know. Will need to cup my hands round the button to see if it works if I go back for a second viewing. It was a hot sunny day when I looked at it so probably couldn't see the light by the sounds of it. I'm used to the bright red led coming on in my BMW X5, and same for the 54 plate FFRR I had previously.
Post #439944 29th May 2017 11:29am
GGDR
Fuse No. 20 in the back of the lower glovebox. Cheers, Greg
Post #439951 29th May 2017 12:12pm
Rob99
It is a fairly dim light, I think mine changes between pale orange and pale red Rolling Eyes
You should feel some heat within 30 seconds and in a couple of minutes it should be warm all round. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #439969 29th May 2017 2:07pm
dirtymonkey38
Been back for another look and it works, very dim light though. Should be picking it up on Saturday. Had a look on TOPIx for the options and the mind boggles with some of them, I guess a new post with them may be in order.
Post #440349 1st Jun 2017 7:13pm
