Home > Off Topic > Karchar Pressure washers
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Despite saying I'd rather cut off my arm than by another one, SWMBO bought me one for Christmas having seen me pitch my old one in to the council skip. So today being a bank holiday, what better time to clean all the patio !! However, the whole time I was using it, it sort of hunted as it was running, like stop start stop start, even though I had the trigger firmly held on. Any one know why ?
Post #439994 29th May 2017 5:32pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Low water pressure?
Post #439998 29th May 2017 5:54pm
Mine sometimes does that when I first start - and I put it down to low pressure until it's built up a flow
Post #439999 29th May 2017 6:30pm
Weegie
The last one I had did that all the time. It still worked ok but I think there was a problem with the pump. It could be low wster pressure, as said, but if you rule that out I would be inclined to pursue the warranty. John
GAP iiD BT-Sold
Post #440000 29th May 2017 6:30pm
JPHC
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
This used to happen on my old one. My hozelock end on my hose had a valve in it to stop water coming out, except when you had an attachment on or it was plugged it to the jet wash.Called a Hozelock WaterStop. Very handy except the valve inside pushed slightly on the inlet for the jet washer so didn't get 100% flow of water. Replaced with a straight through hose end and worked fine after that. Jordan
'56 SC 4.2 ‘21-Current
'56 SC 4.2 ‘16-‘18
Post #440022 29th May 2017 9:38pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I'm on my third Karcher. There will not be a 4th. They are pants!.
Good luck. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #440085 30th May 2017 1:42pm
ajac8
Some other useful stuff here perhaps? http://www.fullfatrr.com/forum/topic42808.html?highlight=karcher
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #440086 30th May 2017 1:43pm
I'm on my first Karcher which I bought 23 years ago. Never been the slightest problem. Thumbs Up
Post #440099 30th May 2017 3:18pm
DaveK
I never thought of that and yes, I do have one of those type of ends on the hose !! Will report back whenI have tried a different end.
Post #440113 30th May 2017 5:53pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I have been using this Smile once you have used a petrol one you wont go back.. power is so much better..
although next door seem to get annoyed if i use it too early on a Sunday.. it is a bit noisy.. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #440137 30th May 2017 8:25pm
Gruute
Belgium
Forget Kärcher and go for Kränzle. Hot water, foam spray, high/low pressure everything you want and they last for (almost) for ever. 2017 Range Rover Vogue TDV8 silicon silver
2011 Defender 90 2.4 TDCI Nara Exclusive
2008 Porsche 911 997 4S Black/black
1970 Porsche 911T 2.2 in restauration
1980 Toyota Land Cruiser BJ40 concours winner
Post #440257 31st May 2017 7:12pm
I have a nilfisk, which is ok, but yearn for a kränzle.
Kärcher are krap. Had one once - didn't last anytime. Friend of mine is on his second - bought against my advice.
Post #440278 31st May 2017 9:29pm
p38arover
Australia
Gerni used to be the go to brand. In fact, we use "Gerni" to denote pressure washers much like the British use "hoover"
for a vacuum cleaner. I bought a Karcher after my Gerni died. I've had it for some years.
The pulsating mentioned earlier I only get when the washer is connected to my rain water tank, not the mains water. The low head of water in the tank means low pressure to the pump.
ajac8 wrote:
They are pants!.
Does that mean good or bad? In Oz, "the ant's pants" means very good - much like this Very Happy
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #440296 1st Jun 2017 12:09am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Laughing Laughing Laughing
Post #440300 1st Jun 2017 5:48am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
things just aren't built like they used to be, the world is now disposable, after a few years it's well out of date and probably knackered
Post #442354 22nd Jun 2017 9:26pm
