Home > Technical (L322) > How quickly can fuel go bad?
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
is it carbs or injectors ?
carb check floats and jets
injectors check flow
you say your getting plenty of fuel guessing thats down the at the spark plugs?
try a bit of WD40 down the spark holes before cranking
Post #440031 29th May 2017 10:17pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Thanks for all the input. 3.9 EFi known as 14CUX system.
I've tried easy start and that was no good.
The plugs are quite wet when taken out after cranking. Big Cry 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #440084 30th May 2017 1:41pm
