![]() | Home > Wheels & Tyres > Change of rims - more rubber now! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
looks good mike |
Nice sidewall.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
What tyres you got fitted? Current: TDV8 (3.6) RRS HSE
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Looks cool |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
They are 265/60-18 Yokohama Geolander A/T-S. At 110H, they're fully weight- and speed-rated for the FFRR, which keeps my insurers happy! ![]() Mick ![]() ![]() ![]() ' |
Just a pattern I've never seen before.. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Good tyres Geolanders |
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 680 ![]() ![]() ![]() |
i genuinely believe the fat high profile tyre look will be "in" again in the future , maybe a while though. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
G'day Mick
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770 ![]() ![]() |
MY10 has the 3.6 and twin piston floating calipers, same as used on the 3.0 D4 and the na 5.0 MY11/12 available in Oz so Compomotives fit. They are locally (for me) owner-certified legal modifications to replace the 6-pot Brembos on my 4.4 TDV8 because the na 5.0 has them as standard. |
None at all - fitted okay over the stock sliding calliper (as they also do with the 4-pot Brembo set-up). The rears were a LOT tighter - I actually had to wire brush the callipers a bit, to remove the built-up surface crud ... Regards, Mick ![]() ![]() ![]() ' |
Your comment about Compomotives on the rear being a tight fit is interesting because standard 18" D4 rims fit my MY12 rears with about 3mm clearance. |
Strange! But then again, mine is a pre-pro model, so may have some slightly different parts to standard. Regards,
Graeme, are you saying D4 calipers are suitable for the 4.4 L322, which allow compo 18's? Do the rotors need to be changed?
