Home > In Car Electronics (L322) > Tow Bar coding
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
Tow Bar coding
Hello.
I had the tow armature and bar fitted the other day by someone PF Jones arranged (mobile mechanic). Went really well until it came to coding the vehicle. The instructions with the electrics was that the 2009-2012 L322 needed coding but when he plugged his tool in, it didn't give the option to enable the towing bits. He called the support people for the tool he was using (I believe it was Westfalia) and they told him that model wasn't supported by the tool.
The main problem seems to be the reverse sensors do not disengage when the trailer is attached but all the lights work (including the body fogs being disabled when trailer ones are connected) as does the trailer indicator when indicating.
Has anyone come across this before? Is this something that the iidtool will sort as I have one on my list of things to get soon?
Thanks.
Ian. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #440400 2nd Jun 2017 9:58am
looks like the iidtool can,
Post #440401 2nd Jun 2017 10:02am
Yes they will need coding, to get full functionality, and they can be programmed for the type of socket you are fitting as you can see from Stans image above.
Either IID job or a trip to the dealer/tow bar centre or an indy with decent diagnostics. There is nothing that can't be fixed with a hammer😜😜
Post #440455 2nd Jun 2017 6:03pm
stu
Hi, I've recently recoded all mine as I changed from 7 pin to 13 pin electrics. Everything is in the IID tool menu. The sensors etc will turn off. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #441017 8th Jun 2017 8:42pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
My rear fogs still come on when my 13 pin is connected!
I've looked through my iid and it just gives a simple on or off ! Or am I missing something in the programme??? 2014 vogue se
Post #441052 9th Jun 2017 9:38am
ianmacd
Mine wasn't coded at all and it was doing that. Not tried it since I have coded it since I don't have a trailer with fogs (the fitter was testing with his test board). Maybe its a function of the later ECU's and is built in as standard rather than something that gets turned on or off (maybe for safety)?
I have by iid tool now and enabled the towing options.
Post #441054 9th Jun 2017 10:59am
