Home > Technical (L322) > What is this?
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
What is this?
Cleaning out the inside of the RR I found a removeable cover under the console cupholders.Under the cover is something that can be pulled....I think it is marked red.What is this for and how does one use it?Is it to put the car in neutral when the battery is flat?The D3 had such a device.
Behind the right hand cover in the luggage compartment there is a cable with a loop on(close to the emergency release of the fuel flap),is this the emergency release for the handbrake?
None of these items are covered in the owners handbook.
For some reason the TPMS does not want to accept "heavy load"as a setting?Am I doing something wrong??Or is there a software problem?
Thanks 2012 TDV8 Vogue SE 4.4
Post #440434 2nd Jun 2017 3:20pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I think it's for releasing the handbrake.
Post #440437 2nd Jun 2017 3:45pm
the pull in the rear cubby releases the handbrake
the pul under the cup holders puts the car into neutral so that it can be moved should it get stuck and need to be recovered when in park, i.e. to load it onto a flat bed when the engine won't start. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #440444 2nd Jun 2017 4:32pm
Frans@Yamorna
Thumbs Up Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #440449 2nd Jun 2017 5:20pm
