![]() | Home > Technical (L322) > 4.4 tdv8 fan belt help |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
there is a tool to get it on which clamps to the pulley and "winds it on" as you turn the pulley by hand with a bit of pressure on the side of the belt according to rave. Requires special tool number 303-1500
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883 ![]() ![]() ![]() |
Is this the first report of one failing?
Further to NMJ's reply.
Dogfishdave Member Since: 09 Feb 2016 Location: Bristol Posts: 76 ![]() ![]() ![]() |
Thank you both for your response, she has just touched 91,000, when I went to see how they were getting on last night I did note the auxiliary belt was sitting about 10mm of the tension pulley. I don't know if the pulley had been tightened up at this point but I will ask him to check it out, looks like I may need a new pulley as well.
yes, that doesn't sound right. the pulley is self tensioning/spring loaded, it was probably seated when they put the belt on, and they have turned the engine over and its moving off. If they still have some of the front of the engine apart swapping the tensioner shouldn't be too tricky/expensive.
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 ![]() ![]() ![]() |
I had belt snap last week. Now I know what the noise was when warming up. All pullies look OK and adjuster . I was hoping one pully would be suspect at lest.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
I had a ‘chirp’ on mine in the mornings, Indy thought the my tensioner(s) we’re ‘just starting’ to wear at 98k so had all belts & tensioners done before anything let go. Expensive, but she’s all done & good for another 98k😁 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Just an update .
