|  | Home > In Car Electronics (L322) > HK Denso audio problem |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Welcome,
|  2nd Jun 2017 4:52pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | try a battery reset........  | ||
|  2nd Jun 2017 4:58pm |
| Monsavon Member Since: 02 Jun 2017 Location: bordeaux Posts: 4    | sorry i forget to update the post, i just copy past from an other forum.
|  2nd Jun 2017 5:22pm |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3277      | To be pedantic the procedure for a hard reset isn't in WIKI (unless I am missing something).  Battery disconnect and reconnect are but not the extra bit for the reset> John
|  22nd Aug 2017 11:58am |
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817      | well if its anything like the HK system in my Mercedes , one of the units will have failed , they are very unreliable , mine needs a new amplifier | ||
|  22nd Aug 2017 9:16pm |
| jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299      | Hi I have a similar problem I have just posted details about the issue I have really strange that after I did a rest by taking the main fuse out for the the infotainment system. I then waited for 10 minutes and also disconnected battery upon reconnecting the battery I noticed my date was back to Dec 2003 how can this be if my car was manufactured back end of 2005 and when I replaced a battery on the car a few months ago the date went back to Sept 2005 which would make sense as a default setting as the car was made 2005 an ideas is this suggesting a software update or something which could cure the problem with the infotainment system I have.
|  24th Aug 2017 1:36pm |
| jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299      | Hi did you manage to sort out this problem as I have the exact same issue and cannot get to the bottom of it.
|  7th Sep 2017 6:20am |
| Monsavon Member Since: 02 Jun 2017 Location: bordeaux Posts: 4    | i managed the probleme, only by changing the main unit. | ||
|  13th Sep 2017 12:02pm |
| jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299      | Hi you say that you changed the main unit do you mean the touchscreen or the unit behind the touchscreen.
|  14th Sep 2017 9:15am |
| Monsavon Member Since: 02 Jun 2017 Location: bordeaux Posts: 4    | the touchscreen. | ||
|  14th Sep 2017 1:17pm |
| jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299      | Right ok thanks for this I have checked every module on my vehicle and bypassed them so it must be my touchscreen also that is causing the same problem that you had. I cannot turn the volume up or down on headunit I cannot select TV , CD, DVD, AUX but I can select REAR SEAT SCREENS and watch TV ,DVD on them it's just limited functions on the main unit. Also I cannot access voice recognition but I can access 4x4 info and the trip computer and the sat nav works also.
|  14th Sep 2017 1:43pm |
| Posting Rules
