![]() | Home > Maintenance & Mods (L322) > 2006 TD6 which brake system ? |
oldman Member Since: 21 Feb 2016 Location: Bucks Posts: 8 ![]() ![]() ![]() |
I am told the pads for my 2006 l322 could be 1 of 2 systems Lucas or Teves? How do i tell which ?
Front or rear? The rear are all the same across the engines iirc, only the fronts change but hances are being a 2006 it will be the later pads for the front. I've never had a problem ordering mine from LR or eBay even FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
As GDM said you should have TRW brakes if it is a Ford era TD6 , quickest way to check is you should have ventilated rears as well. 2008 MY Supercharged
