Home > Maintenance & Mods (L322) > Antifreeze change 3.6 TDV8
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Cant find a post on how to change antifreeze on my 2007 3.6 tdv8 vogue se can anyone point me in right direction Thanks
Post #440746 5th Jun 2017 9:08pm
sako243
It's in the workshop manual (wiki) but broadly speaking there's a tap on the bottom of the radiator (passenger side if I remember correctly), you'll need to open up a cap or two to allow air out.
Fill it up, start the engine and top up as required. Once it's stabilised a bit then run the heater on max until you get warm air coming out of the vents (shouldn't take very long, if it does you've likely got an air pocket).
It does self bleed if you open the bleed screw on the expansion bottle and close when no more air is coming out.
Note I've just gone from memory here so worthwhile checking the WSM for complete details of you want them. Ed
Post #440756 5th Jun 2017 10:52pm
