![]() | Home > Technical (L322) > TRANSFER BOX OIL LEAK |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
HI GUYS.
hi there
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
The transmission and transfer box are separate components with separate (different) fluids. There is no gasket between the two. The transmission output shaft and the transfer box input shaft each have a lip seal to prevent leakage. The mating face of the two casings has a weep hole cast into it so that any leakage from these seals is apparent.
hi phil
just another point, if it is red fluid, denoting the gearbox seal, can this seal also be replaced with the transfer box out and leaving the gearbox in situ ??
hi guys
The book time for removing and replacing the transfer box (41.20.25/99) is 2.2 hours and the input shaft oil seal replacement (41.20.50/01) is an additional 0.1 hour.
hi phil
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
that appears to be some level of forethought and planning by the Gbox designers there........ which is unusual |
