![]() | Home > Maintenance & Mods (L322) > spare hour or so today |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
Nice result. |
| hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294
Nice job, mine is getting a bit tatty in places, going to have to do something with it, looks good........ |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
nice Greg |
| gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077
I'm really pleased with the result. The hdc and hi/lo range levers just pull off, you have to be confident. The switch connectors underneath are a bit fiddlyand I managed to take the trim off without removing the gear knob and gaiter. Powerful uk do a you tube video, and with the new sticker they supply a torx bit, but I found mine wasn't torx, I used a ph2 bit to undo the circuit board underneath. If you are replacing the sticker this needs to come off, as the hdc and hi/low trims cover it slightly. For first attempt it went really well. |
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
Very impressive Greg, looks like pro job. |
| All times are GMT |
