![]() | Home > Technical (L322) > TDV8 Turbo Issues? |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Mine did similar but it was white smoke and a turbo impeller shaft had snapped , hope it's not too serious for him 2015 4.4 AB
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
sounds like turbo failure, maybe ingested a bit.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1881 ![]() ![]() |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
What mileage should I start saving for a new pair of turbos. This is one thing I keep wondering whether I should replace while the car is under lease. ______________________________
I have replaced turbos as low as 60k miles, and as high as 140k miles
Mine went at my just over 140k miles 2015 4.4 AB
I'm at 265,000km so about 165, 000 miles. ______________________________
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Mikey - you are the resident turbo expert and I know I am likely asking questions that other 3.6 owners either have heard answers to before or are too afraid to ask. I also know it's a topic that's been done to death so I'll apologies up front |
Good questions. Except Q5 probably only applies to the 4.4 tdv8.
As said above,
Looking at others threads prevention is better than cure. I was lucky that when mine went the bits fell into the exhaust and not the inlet. When to replace is a big and expensive question. I'm a believer in non genuine parts for many reasons other than cost. Mainly because LR don't own a turbo manufacturing plant so they buy from a third party. As regards new turbos , again I'm not a fan , this time due to money. As reconditioned turbo , using correct quality seals etc is tested and balanced on the same machine as the manufacturer, so why pay over the odds ? The 3.6 turbos are quite small maybe that's why they don't last ?? 2015 4.4 AB
1. Drive gently until fully warm. Not just until the coolant is up to temp, it takes much longer for the engine oil to warm up. Change the oil and filter every 10k MAX. Use only good quality oil and filters. After a drive, allow to cool before switching off, to prevent heatsoak within the bearings. Consider replacing the oil feed pipe at 80k miles... 2. Not really. They just go pop 3. Prevention is always better than the cure. A few quid spent on oil + filters is always going to be cheaper than a pair of turbos... 4. Always advisable. If ones turbo has gone pop, it's likely the other is not far behind it... Price to repair is dependant on the repairing garage. A brand new OEM turbo is best part of £1000 + VAT each, and I wouldn't use anything else. Recon turbos are very hit and miss, as calibration can only be done at the BW factory (unless things have changed recently) ![]() |
Anyone know part numbers for the FFRR 3.6 turbos, and where to buy them? ______________________________
RH - LR004526/LR008829
